TwinTurbo.NET: Nissan 300ZX forum - Correction - engine doesn't need to keep running but the
jzack
on March 29, 2014 at 11:23 AM
Sadly doesn't store it - only remains on as long as the car
posted by jzack
on March 29, 2014 at 11:20 AM
ignition key needs to be not turned all the way off (all systems powered up)....
ABS noises
mskdallas
19:20:50 03/27/14
Any ABS trouble codes? Did you run the procedure to
jzack
22:51:11 03/27/14
no he hasn't. I would expect there would be an ABS light
aliaZ
12:13:53 03/28/14
assuming the bulb is still good - these cars are getting
jzack
22:48:09 03/28/14
I don't recall the ABS motor making noises when the car
aliaZ
12:16:02 03/28/14
I suspect that you'll have to find a way to datalog
aliaZ
12:18:28 03/28/14
Agree
-Grimm-
13:51:28 03/28/14
FYI - Was told by a local mechanic here that the wiring
jzack
22:55:26 03/28/14
thanks for that
aliaZ
10:52:44 03/29/14
jzack
11:20:29 03/29/14
Correction - engine doesn't need to keep running but the -
jzack
11:23:58 03/29/14
did the ABS light ever come on in the dash?
aliaZ
17:12:34 03/29/14
Pretty sure it did - then went away when the car was
jzack
22:24:31 03/29/14
